Audio SUMMA debuts Silverline Audio’s SONATINA MKIV at RMAF 2010!
sonatinaiv
Sonatina MK IV is designed for unparalleled elegance and engineered for exceptional performance!
Silverline Audio’s new Sonatina MK IV enhances the legend…
Design Features
In the winter of 2007, Silverline began to modify the technical specifications of its legendary sweet Sonatina speakers.
The new Sonatina MK IV puts forth a giant step to provide a solid full range speaker system to accommodate the most demanding audiophiles and music lovers. The design team at Silverline developed an integrated driver system including an ultra light-weight and extremely rigid diaphragm made from treated pulp paper cones for the midrange and bass drivers.
In addition to using the best possible components and parts available today, both drivers employ redesigned magnetic motors based on the latest technology. A 7″ rubber surrounds the pulp paper stroke bass driver equipped with a two-inch double-layered voice coil. The heart of the driver, the T-yoke, uses specially selected metal treated and tempered collaterally with the double magnets motor design.
The goal is to not just improve the power handling and efficiency, but also unveil every detail of the shadings and decays in the reproduction of music.
Specifications
Design (Bass Reflex): 3 way full range
One 1″ silk soft dome tweeter
One 3.5″ treated pulp paper cone mid
range with rubber surround
One 7″ long throw treated pulp paper cone
woofer with double magnets
Frequency Response: 25 – 28,000 Hz
Sensitivity: 91 dB (+/- 3 dB, 2.83V)
Nominal Impedance: 8 ohms
Crossover Frequency: 1500/3500 Hz
Recommended Power: 10 – 500 watts RMS
Dimension (H x W x D): 40″ x 10″ x 14″
Net weight: 55lbs (25 kgs)
Shipping Dimension (H x W x D): 43″ x
14″ x 17″
Shipping Weight: 65 lbs.(30kgs)/ Each
Speaker Connections: Bi-wire
Price: US$5,995 per pair
Finishes: Rose Cherry Veneer
www.AudioSumma.com
P. O. Box 1509, San Pedro, California, 90733-1509
Tel: 213.509.0738, Email: sal@audiosumma.com
“delivering sound for your life!”
Audio SUMMA selectively represents the following high performance audio manufacturers of premium quality loudspeakers, vacuum tube and solid-state amplifiers/preamplifiers, analog (vinyl) and digital source components, cables, and vibration isolation products for stereo (2-channel), and home theatre (multichannel) audio systems:
Silverline Audio (http://www.silverlineaudio.com/);
Blue Circle Audio (http://www.bluecircle.com/);
Music Reference (http://www.ramlabs-musicreference.com/);
Parasound (http://www.parasound.com/);
TTWeights Audio (http://www.ttweights.com/);
Tri-Planar (http://www.triplanar.com/);
Analysis Plus (http://www.analysis-plus.com/);
BEL “The Wire” (http://www.belwire.com/);
Transfiguration Phono Cartridges (http://www.audiosumma.com/);
EquaRack (http://www.equarack.com/);
RAM Tubes (http://www.ramlabs-musicreference.com/);
Target HiFi Stands (http://targethifi.co.uk);
Audio SUMMA is Sal Zambrano, a civil engineer with an interest in reproducing live
music…
