Editorial Reviews | Feature Articles | Pro-Review
HiFiMan HM-801 Portable HiFi PMP Review
Features
Modular Design: Modular Amplifier Bay (Named GanQi Bay) and 14.8 volt Lithium Polymer Battery Bay
Memory: SDHC Card
Volume control: ALPS Analog Attenuator
DAC function: Coaxial (16bit 44.1kHz to 24bit 96kHz) , USB DAC (16bit 48kHz)
DAC Chip: Burr-Brown PCM1704;
Op-Amp: OPA627 Exchangeable Module Battery
Charger and External Power supply: External Power supply also acts as a bettery charger and can deliver Hi-Fi grade sound quality even while charging.
Accessories
Lithium ion polymer battery;
Charger/External Power Supply (110-240VAC, 50-60 Hz);
USB cable;
RCA-to-Mini adapter for digital coaxial input.
Specifications
Weight: about 260g (Main Body), about 2000g (include packing box and accessory)
Size: 114 mm *78mm * 25.5 mm or 4.49 * 3.07 * 1.00 Inch
Output: Headphone out; Line out
Battery Life: 7 to 8 hours (Depending upon which Modular Amplifier board is mounted)
Music Format Support:
APE Fast、Normal、High Mode
AAC 16K-320Kbps
FLAC lossless VBR 16bit and 24bit
WMA 8-355kbps
OGG Quality 0-Quality 10
WAV PCM,MS-ADPCM,IMA-ADPCM
MP3(VBR) 8-320Kbps
Wordpress Comments:
  • adam says:
    No – No body interested in a different PMP – has the iPod already won? Is the iPod already in our bass – blowing up our systems? Oh well…
