TEWKSBURY, MA -(Marketwire) — 04/06/09- M-Audio, a part of Avid Technology, Inc. (NASDAQ: AVID), today introduced the new Studiophile® DSM3 active studio reference monitor, providing superior monitoring capabilities for audio professionals. The Studiophile DSM3 monitor delivers exceptional accuracy, clarity and dynamic range via a number of unique design elements including onboard digital signal processing (DSP), carefully matched components and a dual-woofer configuration.
The Studiophile DSM3 monitor is the result of a strategic engineering collaboration between Avid’s M-Audio® and Digidesign® product lines and features a unique hybrid midwoofer-tweeter-midwoofer (MTM) design. This configuration delivers the sound of a larger monitor and flexibility of horizontal or vertical placement, allowing users to position the monitor a variety of different ways while maintaining consistent sound. The MTM design also maximizes the horizontal radiation pattern coherency for a wide and accurate sweet spot with minimal reflections, giving engineers the freedom to move from side to side across the mixing board, while hearing the same representation of the mix.
read the rest on in.sys-con.com
source: in.sys-con.com
Top Features
midwoofer-tweeter-midwoofer (MTM) design > minimizes vertical reflections while widening horizontal sweet spot |
DSP-controlled digital crossover > incredible tonal accuracy |
broad range of onboard digital EQ controls > customizable for your listening environment |
dual 6.5†anodized-aluminum cone LF drivers > exceptionally low distortion |
1†Teteron soft fabric Neodymium HF driver with built-in heat sink > accurate extension up to 27kHz with minimized power compression |
180W Class D bi-amplification > low distortion, high efficiency |
analog and digital inputs > up to 24-bit/192kHz |
high-density cabinet > good damping and reduced acoustic interference |
custom bass-reflex dual-sided flared ports > controlled extended bass response with reduced turbulence |
Wich is better the DSM2 or this one for berklee classes and future pro mixes…????
Thanx
