What You Need To Know About The Polk Audio RC60i
The Polk Audio RC60i In-Wall/In-Ceiling speakers practically have the in-wall speaker race in the bag. They are effectively the benchmark. Their low cost, swivel tweeter design, easy to install, use in bathrooms or saunas, and large dispersion design make them the easy choice for in-wall/in-ceiling speakers. They mimic the look a recessed lighting and you can paint them to match your decor. They will practically disappear in your home.
The RC60i come in 6.5-inch and 8-inch versions, and their Infinite Baffle tuning uses the enclosure of the wall space to enhance their bass response. The hardest part of the set up is going to be cutting a round hole in your wall, but after you have figured that out, their rotating cams a-fix the speaker to the wall. Hook up speaker cabling to the RC60i and run it to your amplifier or home theater receiver and you are set.
The directional tweeter allows the speakers to be used in small to large rooms with a very wide ‘sweet spot’. That means everyone on the couch can perfectly hear the movie you are all watching. Users have reported using them in 28×20-foot rooms with no issues.
The RC60i is voiced to match with the RTi series from Polk, but if you are into mixing and matching, as many people are, the RC60i are reported to pair well with a variety of other speakers. With a frequency response down to 40Hz one should pair these with a sub if you are looking for super deep rumble of explosions or dinosaurs battling great apes.
The warm sound, clear mid range, solid highs and resounding bass is reported to sound best with home theater. For surround sound audio or stereo fronts the RC60i are reported to not perform as well with staging and precision as a set of bookshelf or floorstander speakers of moderate price.
Do you use the Polk Audio RC60i In-Wall/In-Ceiling Speakers?
Let others know how they work for you.
Use the comments below or write a full review using the below links.
More Inwall Speakers from Polk Audio >>
Search AudioReview forums for the Polk Audio RC60I >>
