Feature Articles
Spotlight – SIMPLIFI Audio
(left to right -> PSI A215-m | PSI A25M + PSI A25 Sub | Gradient Helsinki)
(RME vs. Benchmark vs. Resolution Cantata)
( DNM amplifier)
(Tim’s little play house)
If you are interested in find out more you can contact Tim either via www.simplifiaudio.com or check out the bundle offers at hometrialaudio.com.
Wordpress Comments:
  • Peter Gill says:
    Hi Adam
    Just a comment on the HFTN arrangement in the pictures – I’ve just had some made up by Denis Morecroft and only the signal carrying wires are connected to an HFTN. So the cables in the pictures you supplied of the SimpliFi cable should only have 1 HFTN at each end of the cable. Not sure what the effect on sound quality would be if a signal carrying wire and a ground wire is connected to an HFTN (perhaps not as good as it could be).
    Regards
    Peter Gill
